Driver's window died... give a once-over and tell me what you guys think
Old Jun 19, 2006 | 06:59 AM
Factor47's Avatar
New Member
Default Driver's window died... give a once-over and tell me what you guys think
Ok so my window stopped responding on me. At least its rolled up atm
There's kind of a barely audible click but that's it. all the other windows work fine and I've tried the key with the same results.
Before it died it was acting kinda squirrely, it wouldn't roll all the way down (stopped about with about 2 inches to go), and it would also sometimes cause a loud (really loud) buzz through the speakers when rolling up.
The window got broken a while back and I had to have it replaced, I'm thinking some piece of glass might have gotten stuck in there somewhere as I was finding glass for months later.
So its pretty much either the regulator or the motor, right? I'm thinking the motor... anyone know about how much they run and where to get one? Thanks....
Old Jun 19, 2006 | 07:44 AM
The Black Knight's Avatar
Local salvage yard!
Old Jun 19, 2006 | 07:50 AM
Factor47's Avatar
New Member
Default a complete sentence would be great, thanks.
empty posts with 5 words or less in the subject aren't very helpful.
It's like no one here knows there is a whole other field for the body of the post.
Old Jun 19, 2006 | 08:11 AM
Default you ask for help........
then complain about it.......maybe you should rethink that, and if you didn't undersatnd what i said? i think something is wrong
Old Jun 19, 2006 | 08:42 AM
AudiMick's Avatar
Default Did you change the regulator last time?
The clips break all the time but it should last longer than that. The regulators are relatively cheap (less than $150). I would take the door apart and have a look.
Old Jun 19, 2006 | 09:10 AM
BJC::wokka wokka's Avatar
Elder Member
Check out Purems for new window motors.
Old Jun 19, 2006 | 09:11 AM
xdriver's Avatar
Default id guess it isnt the clip, the motor would still run wouldnt it? *edit*
I would take the door panel off and look in there. You can run the window without the panel hooked up by using a paperclip on the harness, at least that way you can see whats going on. enjoy, windows are fun It could be glass in there too and hold it back making it think the window is all the way up/down. get in there and look. I just fixed an 87 acura legend window that a tooth was slightly bent (differnt setup than our cars) but that tooth made it not move at all, and there was only the clicking sound as well (we thought it was the motor till we saw the tooth)
Old Jun 19, 2006 | 09:20 AM
Factor47's Avatar
New Member
Default Re: Did you change the regulator last time?
I'm pretty sure the regulator was never changed. I remember it going up and down just no glass.
Looks like the door's coming apart tonight! need to test out that motor anyway...
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 19, 2006 | 09:22 AM
Factor47's Avatar
New Member
Default wasn't trying to give you a hard time sry
post was just kinda short and I didn't realize you were responding only to the last part of of my post.
Old Jun 19, 2006 | 05:07 PM
qazimo's Avatar
Force5auto.com
LightningMcQueen
Jan 25, 2009 10:59 AM
specialblend
Apr 27, 2008 02:06 PM
yellowssm
Mar 4, 2005 07:02 PM
bujie
Nov 18, 2004 05:36 PM
