Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Changing Tires and I have run out of swear words Please Help!!
Old Dec 29, 2000 | 02:53 PM
Vyse's Avatar
New Member
Default Changing Tires and I have run out of swear words Please Help!!
I have a 1999 A4 Avant. I'm changing to winter tires and I am having trouble removing the wheels. After removal of the lug nuts the wheel will not come off.
HELP!!!
Hugh
Old Dec 29, 2000 | 03:04 PM
steve@s4.org's Avatar
New Member
Default get a rubber mallet...
typical problem in some regions. just give it a few good whacks with a rubber mallet. In extreme cases, it may help to kick the tires. At least it made me feel better...
Steve
Old Dec 29, 2000 | 03:29 PM
MarkFank's Avatar
Default Re: Changing Tires and I have run out of swear words Please Help!!
After you get them off try using som anti-seize compound on the area of the wheel that makes contact before you reinstall. I had the same problem too. I gou mine off by kicking the tire a few times, but not hard enough to knock it off the jack!
Old Dec 29, 2000 | 05:07 PM
RKA's Avatar
RKA
AudiWorld Uber User
Sorry, I answered already in the A4 forum...it's pretty easy.
Old Dec 29, 2000 | 09:22 PM
Milpitas2.7T's Avatar
AudiWorld Expert
Steve is right, rubber mallet or some good kicks from behind. Make sure you are on jack stands!!
Old Dec 29, 2000 | 09:32 PM
Vyse's Avatar
New Member
Thanks Everybody 10-30 good kicks size 12 Red Wings (nt)
Old Dec 30, 2000 | 11:19 AM
kcS4's Avatar
Junior Member
coat the surfaces with lubriplate, they won't rust together!
Old Dec 31, 2000 | 09:08 PM
PbPedis's Avatar
New Member
Default 2 tricks that have never failed
1. loosen the lugs, then let the car back down to the ground
2. if that fails, with the car on the ground, drive a couple of feet and slam on the brakes
after that, be sure to use anti seize.
 Pouria Savadkouei
 Michael S. Palmer
tigers7
Q5/SQ5 MKI (8R) Discussion
18
May 22, 2016 05:44 AM
RobMate
41
Jan 29, 2014 05:05 PM
EGRoadster
Apr 14, 2006 07:59 PM
luvmyaudi
Jan 11, 2001 10:15 AM
Vyse
Dec 29, 2000 05:00 PM
