Changing Tires and I have run out of swear words Please Help!!
I have a 1999 A4 Avant. I'm changing to winter tires and I am having trouble removing the wheels. After removal of the lug nuts the wheel will not come off.
HELP!!!
Hugh
HELP!!!
Hugh
get a rubber mallet...
typical problem in some regions. just give it a few good whacks with a rubber mallet. In extreme cases, it may help to kick the tires. At least it made me feel better...
Steve
Steve
Re: Changing Tires and I have run out of swear words Please Help!!
After you get them off try using som anti-seize compound on the area of the wheel that makes contact before you reinstall. I had the same problem too. I gou mine off by kicking the tire a few times, but not hard enough to knock it off the jack!
2 tricks that have never failed
1. loosen the lugs, then let the car back down to the ground
2. if that fails, with the car on the ground, drive a couple of feet and slam on the brakes
after that, be sure to use anti seize.
EGRoadster
04-14-2006 07:59 PM
luvmyaudi
Wheels & Tires Discussion
01-11-2001 10:15 AM
Vyse
12-29-2000 05:00 PM
