Atlanta Meetup 9/3 at Noon
When: 9/3 (First Sunday of each month)
Time: Noon
Where: Behind Park Place shopping center
Directions:
1. Exit Ashford-Dunwoody Road from I-285.
2. Go North on Ashford-Dunwoody.
3. Just past the Exxon station, turn right into Park Place shopping center.
4. Go left around to the rear parking lot.
<a href="http://www.google.com/local?f=q&hl=en&q=4505+Ashford-Dunwoody+Road+30346">MAP</a>
<img src="http://pictureposter.audiworld.com/39523/atlaw.jpg" />
Time: Noon
Directions:
Sort of...
None of the dealers had them in stock so I ended up getting a bolt from Hans that came off a 1.8T. It turns out that the 1.8T bolt is a little different so I didn't use it. The end of the bolt is flat, where the 2.7T bolt has a taper.
The original bolts have both twisted and one was cracked. They fit somewhat loosely into the holes with a little bit of wobble. The 1.8T bolt seems to fit much better. I'm going to guess that new 2.7T banjo bolts will also fit better.
Hans informed me that the line in question is actually a vacuum line, so really they don't need much torque. I'm going to order new bolts and try again.
The valve cover gasket I got from ECS is for a 1.8T so I couldn't work on that. Today all we got done was to install the transmission and replace the center torsen diff with a 4:1 Stasis unit.
Next time I just need to install the banjo bolts and new valve cover gasket and the motor will be ready to go back in the car.
Here's a pic from last week showing the LWFW.
<img src="http://maxhawk.flagshiphosting.com/misc/k04_flywheel_800.jpg">
And with the clutch installed:
<img src="http://maxhawk.flagshiphosting.com/misc/k04_clutch_800.jpg">
I haven't been taking as many pics as I wanted. My gloves get dirty and I don't want to keep replacing them every few minutes just to take pictures.
Hmm, maybe 5 partial days
Last weekend for example all we did was install headers, turbos, and clutch. This past Sunday we put the transmission back on and started the valve cover gasket.
I think the longest day I've worked is maybe 7 hours (including lunch). The shortest has been around 3 hours. So let's call it 25 hours.
Audi A6 2001 A6 2.7T 6MT Melange 70,891
ScottCNelson
09-27-2015 02:41 PM
Joe Black
08-23-1999 11:31 AM
