Suspension Tuning Discussion Discussion forum for general topics regarding suspension tuning
'06 A6 3.2 handling needs
Old 03-30-2016, 08:21 AM
LarryJa's Avatar
Default '06 A6 3.2 handling needs
I picked up an '06 A6 3.2 quattro about a month ago. After taking a few good trips with it, I've got a good idea of how I'd like to improve on it's good handling. It understeer too easily. It's not an S-line. So, it's ride is pretty good & I want to keep it that way.
1st, the front struts are too soft...so, s-line struts are in order. Then, a good rear sway bar would cut back on the understeer. So, will pumping up the front tires a little more, too.
What do you think? Any other straight forward suggestions.
It's got the 18" continental on it, which I really like, especially in the wet.
Old 03-30-2016, 03:30 PM
raj99's Avatar
Best thing you can do is install a rear sway bar and then get appropriate coil overs. It'll change how your handles dramatically.
Old 03-30-2016, 10:54 PM
LarryJa's Avatar
Thanks! The rear bar is a definite. At the same time, I'd like to save the smooth ride of this car. However, the front struts feel a little soft. So, they'll get replaced. Idk if I'm leaning toward b6 or up to b8 bilsteins. Like I said, I'd like to keep the good ride, & even the ride height too.
I do a good amount of driving in cities, where the roads can be broken up &.potholes. So, I still need a compliant suspension.
Old 04-29-2016, 11:11 AM
LarryJa's Avatar
Well, I ordered the H&R rear bar. The next thing will probably be the Michelin 3+'s to replace the Continental Procontacts.
Old 05-25-2016, 08:07 AM
LarryJa's Avatar
I'm looking at putting stiffer front sway bar bushings & koni strT shocks on, in addition to the H&R rear bar.
I'm still undecided on tires, but I have a little time on that.
Old 05-27-2016, 07:33 AM
LarryJa's Avatar
I've noticed a little front end looseness on "rippled/patched" pavement. I haven't gotten under there, yet, to check out the bushings but, I'm inclined to suspect the sway bar links. Nothing big, just noticeable to me. How common is replacement of those links?
Old 07-17-2016, 02:54 AM
LarryJa's Avatar
Well, I've got a set of koni strT front struts coming in & I'll have my indy put them in. I'll do the H&R rear bar myself.
I haven't found any loose bushings in the front end, but he'll find anything that i missed, when he changes the struts.
I am feeling a little looseness around town in the front end. On the highway, everything is fine & solid. So, i think the new, tighter front struts will take care of that.
I can't stand the amount of understeer that i get on access ramps, etc. That big rear bar will definitely solve that.
We'll see how this goes.
Old 07-25-2016, 08:04 AM
LarryJa's Avatar
My front struts were on back order, & my money was refunded. Koni NA has them back in stock now. So, the tire rack will get another order from me.
Old 08-06-2016, 03:19 AM
LarryJa's Avatar
I got the front struts this week from the tire rack. Next week, the indy will install them.
The rear shocks are in shipment to me. I'll install them & the rear bar myself. However, I'll be changingchanging the trans filter & fluid, first, tomorrow.
Old 09-07-2016, 05:24 PM
LarryJa's Avatar
The struts, shocks & rear bar are done.
What a transformation!
The rear bar upgrade cured the understeer. The car is real close to neutral now.
The strut & shock change to the koni strT's stiffened up the around town ride & handling. The front end is more connected feeling now. Which is just what I was after.
So, it all worked out well, & I'd recommend that rear bar & koni strT shocks to anyone.
Trevor Chase
13
02-19-2017 01:03 AM
WojtekA4
Canadian Discussion
03-05-2006 02:55 PM
Audiboi 2.7T
A4 (B7 Platform) Discussion
07-19-2005 09:36 AM
A6 Quattro UK
9
06-25-2002 11:43 AM
Milpitas2.7T
02-19-2002 03:57 PM
Quick Reply: '06 A6 3.2 handling needs
