2001 All Road Suspension Acting Wierd
David
You need to put Ross tec on Car...
Dont worry its not hard get to figure out what's wrong as their is only a few steps to diagnosis...
With out the Ross tec platform It can be difficult to find out what's wrong and will straight forward with it...The module doesn't need re calibration only if the leads to the battery have been disconnected and the micro controles inside the module depleted( memory set to default) That alone the car is randomly dropped Some times the valve solioned block which is located under the boot outside underneath car between driff and foot well can be faulty this can cause random dropping or escapeing of air and then the module tells its to fill again..Yes it could be faulty sence switch which is also connected to the air suspension module, The best way forward is get the Ross tec platform it is very robust and very straight forward.. The suspension module is (34) on the software that you can test and re tune the costs of replaced parts a very low ....kind regurds
