Wheel Alighment figuires
Paging all experts..... What do you think of these figuires of before and after.... The Car is running Custom Valved Koni Shocks and H&R S4 springs with neuspeed 19mm rear swaybar....
Front Before:
Rhs Lhs
Caster: 5.1 4.4
Camber: -0.2 -1.2
Toe: -3.7 -4.3
Total: -8.1
Front After:
Rhs Lhs
Caster: 5.1 4.4
Camber: -0.2 -1.1
Toe: 0.0 0.0
Total: 0.0
Rear Before:
Rhs Lhs
Camber: -1.5 -1.7
Toe: 3.7 -2.5
Total: 1.2
Thrust Angle: -0.3
Rear After:
Rhs Lhs
Camber: -1.6 -1.6
Toe: 0.0 -0.6
Total: -0.6
Thrust Angle: -0.0
Front Before:
Rhs Lhs
Caster: 5.1 4.4
Camber: -0.2 -1.2
Toe: -3.7 -4.3
Total: -8.1
Front After:
Rhs Lhs
Caster: 5.1 4.4
Camber: -0.2 -1.1
Toe: 0.0 0.0
Total: 0.0
Rear Before:
Rhs Lhs
Camber: -1.5 -1.7
Toe: 3.7 -2.5
Total: 1.2
Thrust Angle: -0.3
Rear After:
Rhs Lhs
Camber: -1.6 -1.6
Toe: 0.0 -0.6
Total: -0.6
Thrust Angle: -0.0
Because it would be much easier if you had the specs next to each entry for comparison purposes
Unless you are racing, and very confident you know more than audi, you mainly wnat things within factory spec, whcih almost any machine will print out for you.
Grant
Grant
Your alignment wrench only touched the toe adjustments. Got the front toe right, but not the rear...
For max tire life should be Zero camber, and Zero total toe, centered on the chassis. I don't lurk here, only on the A6 C5 forum.
Bernie said "for maximum tire life" and with that goal, it is probably true....
.. for any car. Minimum scrub; maximum life. May not be factory spec, optimum for handling, nor feel. But scrubbing rubber is in fact wasteful
G
G
Paldi
03-02-2006 07:27 AM
ILLZ
07-14-2004 06:32 AM
Imola Ghost
04-14-2004 05:08 AM
dspy
07-14-2003 06:12 AM
