2015 A6 CNH 2.0tdi: Sudden loss of revs and rough idle
Old Sep 24, 2023 | 11:50 AM
Mikeyk20's Avatar
Default 2015 A6 CNH 2.0tdi: Sudden loss of revs and rough idle
Hi All,
*car loses revs suddenly for 1-2 seconds while driving and can idle bad, no fault codes*
I have a 2015 Audi A6 2.0tdi engine code CNH with just over 100000 miles. The car has been giving some trouble over the past few months. It started with a sudden loss of revs, like a hiccup on the road. This has got more frequent recently and the car has also had two episodes where it has idled very rough and cut out. This could take 2 minutes to clear up.
My family are mechanics and we have worked on a lot of these 2.0tdis and never had an issue like this especially with no fault code present. I have changed the diesel filter (OEM) and I have given the car some of VWs fuel additive for carbon build up. The EGR and AdBlue was also deleted with a map before this became an issue. There is no sign of corrosion on the ECU connectors/casing. I will get a Crankshaft sensor this week and try that.
Any insight or suggestions would be appreciated.
Old Oct 1, 2023 | 10:41 AM
Mikeyk20's Avatar
*Update*
Crankshaft sensor fixed the problem. OEM sensor was €120. Awkward to change but luckily I had the car up on a lift.
mtnboydl
Sep 23, 2021 08:14 AM
Slowaudi04
Feb 9, 2021 11:03 PM
PretendPilot
May 13, 2019 02:26 AM
JohnM12345
Jul 9, 2011 01:03 PM
