Is RNS-E more plug and play in a 2004 AR?
What are you comparing to?
All 2002+ A6 installs are basically the same but without knowing what's on your list it's hard to say what you can skip or what you are missing.
Good point, I was sleeping when I wrote that question...sorry
I read the whole 2001 AR install and it seemed much less than plug and play.
So for an O4 AR;
1. Remove Symphony II
2. Insert connectors/adaptors
3. Adapt for speedo data to the head unit. (removing the cluster?)
4. GET yelled at from my CFO (wife) for spending $1500
5 Drink a beer and watch a DVD.
This seem right?
So for an O4 AR;
This seem right?
speed signal and reverse signal (optional..but recommended) are all you really need...
...just make sure your rnse harness is setup correctly.
also,
1) adding the upgraded sirius/xm module is plug/play in the trunk
2) your ar will have the MF steering wheel....and the integration with the oem BT module is "bad ***".
If you have the oem nav option in your car, you can easly tap into gala/speed and reverse signal in the trunk and not have to pull the cluster or kick panel trim.
...the hard part...is finding a unit for the C5. The are in high demand...and in short supply.
-Ted
also,
-Ted
Ghost98
08-06-2012 10:55 PM
Disher04
09-02-2008 06:22 PM
fazooley
06-14-2002 03:39 AM
