266/311? Am I reading that right? On 100 octane? Was that XR or X?
Nobody knows? Searched for all the info... this is one of the most powerful TT's so far...
And I have his setup with an exhaust... I'm excited to say the least.. though it doesn't feel so powerful anymore.
unfortunately...
if you look at the dyno graph you will see why the info may not be worth anything
think he also used x and xr but couldnt straighten out his situation.
also the way the numbers were coming up, figure a 15% drivetrain loss max
<img src="http://www.imagestation.com/picture/sraid101/p5946004e4c5fc52cd6645551e9bfb91d/f9d5a301.jpg"><ul><li><a href="https://forums.audiworld.com/s4/msgs/1526101.phtml">some more info here</a></li></ul>
Two of us threw similar numbers but with XR + 100 Octane
I don't think you will see these high numbers on "GIAC X-Mode" even with 100 Octane, you will need "GIAC XR-Mode" + 100 Octane, then these numbers are pretty standard for wheel horse power. To get an idea of "Crank HP" divide by .8 and this will give you a ballpark figure. This is how I was told to figure for our Quattro cars due to driveline loss, on Front wheel drive divide by .85.
I didn't post the numbers on the forum because they are not worth anything..
Forget that even happened.. You can't give those numbers a second thought simply because of the amount of throttle cut I was experiencing..
