About the DV and other topics...
What does it mean if the valve does not have a letter: 06A 145 710 (?). Anyone with a FWD with Eibach's (springs and dampers). Which would be better, Eibach anti roll bar(22mm front) or Neuspeed (25mm front/25mm rear adj.). I wanted the H&R coilovers, but the car gets too low (2 to 3 inches lower than original) for Mexico. Has anyone kept the 16 inches wheels and tires? ...
Answers .. .
Neuspeed does NOT make the rear bars for the TT anymore! You would be better off with a 22/25.
The H&R or any other coil-overs have an adjustable height that you can even set to the stock ride height! That is one of the advantages of them, along with a much better shock and spring.
I am sure plenty of people have the 16" wheels and tires. Some might even be using them for snows in the US/Canada/Europe
suspension ?.coilovers or springs and shocks?thinking H&R eibach bilstein 1.75 inch low as i will go
MaXiTT
01-13-2002 11:17 PM
Should i go KW or H&R Coilovers--- If Kw Variant 1 or 2 Pros Cons opinions PLEASE!! THANKS IN ADvanc
AddictedA4
12-13-2001 06:33 AM
So when coilovers (i.e: h&r) are ordered from a vendor, is the ride height pre-set from the factory?
nick n
09-20-2000 05:06 PM
Colonel Bogey
09-07-2000 10:20 AM
