Adjustable front, negative camber solution.
Old Jun 2, 2000 | 11:38 AM
Colonel Bogey's Avatar
Member
Default Adjustable front, negative camber solution.
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/FLCR.JPG"></center><p>The three connecting points on the lower control arm at the base of the hub have elongated holes. Hence, a fair amount of adjustability is already engineered into this part. In fact, it allows for a fairly easy and straight forward manner to adjust by simply lossening the connectors and pulling (negative) or pushing (positive)the base of the hub.
My new found machinist is welding doublers on a spare set of MKI lower control arms and elongating the holes to a wider adjustment range.
These control arms will be part of my upcoming coil over install.
Now, if only the rears would be so easy.
Old Jun 2, 2000 | 11:49 AM
VAP's Avatar
VAP
Default I've been telling folks that wanted camber plates about this for months. Camber plates...
raise a vehicles ride height when mounted in stut tower. This adjustment doesnt and is a little more fidgety to get right without the long fulcrum/axis of the strut to rock but a far better solution.
Grade 8 hardware and Unitork nuts and this is the way to go.
You duh man yerfullbirdship! Which assisted living center you retiring to? We could get in a LOT of troub!
Old Jun 2, 2000 | 12:09 PM
Member
Anywhere except God's waiting room...Florida! (Sorry, ObsessTT)
Old Jun 2, 2000 | 12:22 PM
Lone Starr (Ivan)'s Avatar
Elder Member
Default It's OK, I plan on retiring to a world tour of travel (C'mon Nasdaq!)
<p>Ivan
<i>Jacksonville, Florida<i>
<img SRC="http://www.geocities.com/y2ktturbo/tinytt.jpg" BORDER=0>
"Zorro" 2000MY, 180hp, Fronttrak, Silver/Ebony, MKII suspension, spoilTT
K&N, Garmin EMap GPS, Audi "mask", Cobra R/D
waltern7
Audi Original "S" Cars
Jul 13, 2017 06:45 AM
quattromano
Jun 14, 2014 09:50 AM
87ninefiveone
11
Apr 10, 2008 07:59 PM
gerry14
Feb 16, 2006 10:19 PM
O.W. Kenobi
11
Aug 25, 2003 03:23 PM
