Alignment question
Is it common, or at least make sense to adjust your alignment specs when you start putting wider tires on?
What numbers would you recommend for a 245/40-18?
Thanks
matt
The tire sidewalls are flexible. The contact patch of the tire is going to stay in contact with the road by roughly the same amount despite the camber. Sure, you could radically change the camber, but that isn't even realistic.
