Any of you guys still waiting on CPP control arms from Streetwerke.com?
<rant>
I ordered these suckers with 10% off, on the 31st of January and haven't received anything, not even communication from the vendor about my order.
Just wondering who else picked some up and if you've even received it yet. I'm gettin' kinda frustrated waiting for these, my camber is pretty bad since I've been lowered for awhile now. I don't even know when to expect the product, or if my credit card has even been charged yet. I just sent them an email so hopefully I'll get some info.
</rant>
</rant>
Not to sound any alarms, but I would be calling ASAP
These aren't being made anymore (I know, I keep saying this) and with the 10% off, they may have oversold.
I got mine from Griffin Motorwerke in CA and I got their last set in stock. I've had mine for a week or two now. Just waiting for the right time to put everything on.
Life is hectic right now, so I'm targeting March as the month to get it all done..
Good Luck!
Good Luck!
they definitely oversold
apparently there is quite a bit of miscommunication between the Dave (CCP) and whoever is running Streetwerke. They sold alot more than CPP could have ever supplied them.
You gotta get 'em at AWE -->
I talked with David at CPP since Achtunig and Streetwerke (where I got set #1) were out. I had already purchased from AWE when David pointed out that AWE had them. They are in transit to arrive Friday. Skyler at Achtuning said they cannot get them any more.
I already had a set in the lowers having swapped OEM lowers to the upper position. In this config, toe could not be set on the right side, so I figured I'd get a second set, set the trailing arm back to mid-range and use both adjustable arms to set both toe and camber.
You'll like the upgrade from the bushing to a spherical bearing and the stainless ends. The issue you'll face is that the headlight level adjuster doesn't fit so you'll have to fab something to fix that. I used a set of 3M foam double sided tape squares to get it right.
