anyone here use koni yellow adjustable that can explain how to adjust the damper for the rear.
#12
Ha! I spent an hour or so trying to adjust mine this afternoon.
Apparently they must be removed from the car and placed upside down in a vice to get the adjuster into the detents. At least that is my experience so far. I tried taking out the bottom bolt only and compressing to adjust. Spin spin Spin. I had the white split washer out but the black rubber spacer was not visible. Could you describe how that comes out? Sorry I'm no help. I'm frustrated too!
Maybe we should start a support group:-)
#14
yup have it on my hand right now and i'm turning, turning to the right (clockwise) and it does feel
like it's coming to a stop. but then i put a little pressure and it's free to turn again. seriously what am i doing wrong?
#15
there are two little holes on the "end" part , put a small screwdriver and press that bump stop out.
there's the "top" which has the the part number and an arrow point up. the opposite of that should have 2 holes.
#18
thanks... i think i'm doing something wrong. also did you install these parts yourself or you have a
shop do it? have you play with the damping at all? how many time have you adjust the damper on the rear?
