anyone in the MA area who has bled the clutch >>
and would like to help me do mine? never done one before. also, i'm pretty sure the brake fluid has never been changed. is it true that the clutch and brake share the same fluid? also... what do i have to do with VAG during the bleeding process. or am i just very confused. please someone hold my hand
you need little fingers
to get into the area where the clutch bleeder is... i can't believe you've not done the brakes yet! <grin>
you can use vagcom to cycle the ABS pump but i never bothered (yet) because i bled mine so frequently because the car was tracked so often...
I'm assuming the 225 and APR'ed 180's are the same
<img src="http://pictureposter.audiworld.com/302/clutchbleeder.jpg">
From service manual :
Ensure bleeder hose is correctly fitted during bleeding operation.
- Switch on bleeder appliance.
Working pressure 2.0 bar
- Open the bleed valve -arrow-.
- Bleed approx. 100 cm3 brake fluid.
- Close vent valve.
- Operate pedal 15 times from rest position to stop without interruption.
- Bleed another 50 cm3 brake fluid.
- Tighten vent valve to 4.5 Nm.
- Remove filling device from brake fluid reservoir.
- Operate clutch pedal several times after completing venting procedure.
- If necessary, vent once again
- Close vent valve.
Mr.FRU-T-Pants
Audi Original "S" Cars
19
04-18-2007 01:12 PM
lb
08-08-2005 04:47 AM
