Attention TOOL Junkies!! Cool IR Thermometer deal....>>
AudiWorld Uber User
<center><img src="http://pictureposter.audiworld.com/13940/dscf0913.jpg"></center><p>With all the heat related diagnostics going on, this is probably a tool you can't believe you lived without. Found a cool deal on this Extech #42520. Call Radio Shack at 1-800-the-shack. Catalog # 91-5390. On sale now for only $79.99.
I'm gonna go out and shoot my Turbo, shoot the CAT, shoot the kids, etc. now....see ya
Ahhh, yesh, the Extech #42520, the preference of pros. - Is that the oral or "other" model??? ;-)
But, seriously, what is it's use? Is this intake related? Can you literally just point at something and it'll give you a surface temperature?
AudiWorld Uber User
Lots of uses....>>>
Yes, it measures surface temp from a distance (1" spot at 6" distance). Racers use them to check tire temps across the tread. Helps with suspension set-ups. You can isolate hot spots in engine areas for diagnostic purposes (we use these all the time in the M/C service dept.), etc. I don't think it's designed for oral use though! Use your imagination!
I doubt you can get accurate tire temps with that thing...
Not to say, it won't give you actual tire surface temp, but usually, racers have the probe (tiny needle) kind of pyromenter.
The surface of the tire cools off very quickly, and the heat dissipates across the tread as well. To get accurate tire temps, you have to come into the hotpits at almost full speed, while you have your buddy standing by with the pyrometer. And, then of course you can do the standard inside, outside, middle measurements.
moribundman
10-18-2021 07:27 AM
djillusion
05-22-2003 03:53 PM
Scot J
09-14-2002 09:43 AM
Jimmy D
10-20-1999 02:25 PM
