attention Trent (TT_Nuge)! ... my ride height specs per my tuner...
<center><img src="http://pictureposter.allbrand.nu/pictures/zgtt/tt+pics/profile.jpg"></center><p>he says..."10 threads showing on the bottom of the front perches, the rears are all the way down"
Had my spacers installed yesterday and now have the rear KWv3's on.
Re: no, that is the old pic.
<center><img src="http://www.kodify.com/audiTT/mufflex/ypipe.jpg"></center><p>here's a pic...look at my rusted bottom spring seat...there's an off-white spacer (which has since been removed) and the rubber bump stop above it...it is sandwiched between.
here's a few pictures of the way my rear sits now...but with your rear seat delete...you're going to be higher...maybe due to lightened weight.
<img src="http://www.kodify.com/audiTT/KW/DSC_0028.jpg">
closer shot...
<img src="http://www.kodify.com/audiTT/KW/DSC_0029.jpg">
closer shot...
Is that how they should be when you install them? Or should you >
have them in the middle of the threads from and back when you install?
ORRRR can you have them all the way down when you install?
