The BAMM for the 180 arrived. Testing to comence this weekend...>>
<img src="http://images7.fotki.com/v125/photos/5/58883/1534781/DSCN2832-vi.jpg">
Using the VAG-COM, a base run with the stock MAF will be performed. The BAMM will be installed and a second run will be taken. I'll drive the car for around 200 miles and perform the third run.
After the results are compiled and anaylized by Mr. Schwing and yours truly, I'll post them here, the ol' fotki site and the Modshack TTuned site.
Robert...suggestion>>>>
before you do your second run, clear the ECU. The adaptation will take about 50-100 miles. Then you could still check again after 200...
That is what i have done with the BAMM, and it seems to respond and adapt better on my 225.
Just a thought....Good luck regardless!
But.....We're gonna log block 32 and..>
I want to see which way adaptation is going first. A Before, and after a few miles oughta give us an indication if the 4 bar will be necessary on the 180....
