Boost leak I assume...?
Old Jun 3, 2007 | 10:57 AM
JerseyTT2's Avatar
Default Boost leak I assume...?
TT drove fine yesterday (96 degrees high humidity in Trenton, NJ) for 50 or so miles of normal driving. I started the car late last night after sitting for 2 or so hours (air temp outside dropped to low 80's; car temp dropped to needle on C) and noticed my boost gauge was sitting at zero, no vac, no reading at all. I pulled the gauge out to check my hose connection and it seemed ok; at about this time realized the car was running a little funny (revved to 2000rpm and let off - as needle dropped I noticed at about 1200-1300 the needle bounced then continued to fall). This morning I tested the gauge by blowing into it and sucking out also seemed ok; it recognized my 3psi lung capacity. I plugged the gauge line and drove with out the gauge in, I could hear turbo spooling but it felt like a naturally aspirated 4 cylinder.
When revving the engine the whoosh sound of the dv has changed to a whoo-ch-ch-ch-ch-sh. I removed it, re-greased and re-installed. Test drove again - no boost gauge reading still, dv still sounds like I just described, and the car is pulling like a civic.
Sounds like a boost leak to me, maybe bad dv o-rings(25000 plus miles on forge dv007 same o-rings). Recommendations please...tia
Old Jun 3, 2007 | 11:04 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Even with a boost leak...>>
You'd have Vacuum.....Nose around in the engine bay...Particularly the Boost gauge hook-up,,,,Maybe the line blew off under the manifold..
Old Jun 3, 2007 | 11:23 AM
JerseyTT2's Avatar
Default Thanks for the reply Mr. Schwing...
I'll look around and probably start by replacing my plastic T and possibly running a new hose to the gauge. I'll let you know what happens. Thanks again.
Old Jun 3, 2007 | 11:47 AM
JerseyTT2's Avatar
Default Mr. Schwing, you are good at what you do...>>
<center><img src="http://mail.google.com/mail/?attid=0.1&amp;disp=thd&amp;view=att&amp;th=112f31 743c710996"></center><p>Line from the IM cracked. Thank you High Exalted TT Grand Master.
Old Jun 3, 2007 | 11:49 AM
JerseyTT2's Avatar
Default Better pic...>>
<center><img src="http://mail.google.com/mail/?attid=0.1&amp;disp=thd&amp;view=att&amp;th=112f31 64a85d69ad"></center><p>
Old Jun 3, 2007 | 11:51 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
No Problem....Pure logic on that one!....BTW, Picture no worky...:-)
Old Jun 3, 2007 | 01:17 PM
XCLR8TT's Avatar
Senior Member
Default Nope
<img src="http://images114.fotki.com/v659/photos/4/419847/4413964/red_x2-vi.gif">
Old Jun 4, 2007 | 01:24 AM
invncble's Avatar
That's great.
Old Mar 19, 2009 | 11:30 AM
conman5353's Avatar
Banned
lol noob
NateTT
Nov 6, 2005 12:59 PM
HACK THS
Oct 3, 2005 02:34 PM
Pelican Pete
Nov 12, 2004 07:30 AM
daphne
Mar 23, 2002 05:54 AM
