Busy Day: Installed Roadster headliner, stealth Forge, Roadster sunshade, and pulled my ECU.
Of course, I pulled my ECU just to look at it. I would never do anything like ship it to Auburn, AL or anything like that.
sunshade...
I got the roadster sunshade from Stratmosphere. I've used it a couple days... seems to work well. Perfect fit- even works with my V1 still in place.
It wasn't too bad.
The hardest part was putting the rearmost support in place. I lost the skin on both my middle finger knuckes. This was due to a combination of the tight fit and the high temperature of the fabric and support.
I did all but step 13 myself. It's the part where you attach the liner to the front of the convertible top UNDER the shroud. You have to have someone hold the shroud while you put in some screws.
All in all, it was much easier than I anticipated. TIP: Don't drop the bow screws that you pull out of the roof. If you do, a pan-head 6x1/4" metal screw will replace it.
I love the look. An excellent upgrade.
Re: Busy Day: Installed Roadster headliner, stealth Forge, Roadster sunshade, and pulled my ECU.
For us newbees, what is the headliner, how much $, where do you get it? Same Q's with respect to stealth forge and sunshade. Thanks
It actually all came from Stratmosphere.
Stratmosphere is a sponsor of this board... and the prices are all there.
BTW, the ECU definitely, no way, absolutely did not go to APR. http://goapr.com<ul><li><a href="http://www.stratmosphere.com">Stratmosphere</a></li></ul>
NvFlw
06-18-2004 05:29 PM
