A/C Fan- final post on topic
Folks, there is a ton of info in this forum on AC related issues. Somehow, I am missing the key to solving the problem and face the prospect otaking this beast into the Stealer.
I wanted to make one more desperate attempt to have a savant from the forum give me a hand.
-I have no AC...it blows warm.
-Refrigerant is FULL.
-Driver's side radiator fan does NOT come on. Other passenger side aux fan does.
-Car does not overheat. Temp guage goes to exactly middle.
-Fuses on battery top are fine and we have continuity there.
-I smelled a electrical burning smell just before the cold air went bye-bye
-I havent been able to find anything fried yet
-Fan controller seems healthy (I had a loose wire to battery once which made me go thru this a few yrs ago, and I replaced fan controller then)
Question, if A/C compressor clutch goes bad, would that cause my fan to not operate?
I'm thinking that it must be the fan given the circumstances but I'm looking for opinions.
Any would be welcomed.
Thanks,
wyaTT
Thanks,
wyaTT
your temp gauge is not a good barometer. Check your temps via the HVAC controls which is well documented.
If your AC is off (that includes not being in AUTO mode) then your second fan will kick on at 106Celcius which you can track via the HVAC.
If you do not reach that temp and you are smelling something, it could be the AC clutch...
When you run the AC (Auto counts), both fans should be on...period, regardless of temps. If that is not the case, could be fan or fan relay switch, which is also prone to failure...
i have a problem with my air con.it will blow really ice cold for the first couple of miles or approx 5/8 mins then it blows warm air.i have checked all the usual things&everything is ok.you could check to see if your air con compressor is turning round when you turn on the air con.the pulley for the air con is in the middle of the pulley which is connected to the air con compressor,dont think because the outer pulley is turning that it is working,it is the actual centre of the pulley that turns&only turns when you activate the air con.i only know this because that is the problem i have !!!!when my air con is blowing cold i look at the centre pulley&its turning as soon as my air con goes warm ilook at the centre of the pulley & it has stopped turning!! i have been advised on another forum that the clutch in the compressor could be faulty but i dont want to buy a new compressor until i find out for sure that it is the actual compressor that is faulty.if anybody has any ideas i would be grateful for them
Good luck
sugaryling
17
08-21-2007 05:17 PM
computrtutr
10
07-17-2006 06:27 AM
