Can an APX Engine Code type be replaced by another code
Old Apr 22, 2002 | 09:43 AM
NIIK TT's Avatar
New Member
Default Can an APX Engine Code type be replaced by another code
I am currently searching for another TT engine since a Superchip blew mine up. ( new website under construction ).
I have sourced another 20V Turbo Engine which has the K03 turbo etc however the engine code is different. Will this be a problem mating it with my ECU which maybe programmed with the old engine code information. Would another re-chip solve this problem.
Any advice appreciated.
Old Apr 22, 2002 | 09:59 AM
hoTTub's Avatar
Member
Default APX is not a familar code to me, that may be from an A4 or a Passat....
in which case, the block will fit but everything else will not like manifolds (exhaust and intake) A/C compressors etc....could be more trouble than it is worth.
ATC(TT), AWW(Jetta/GTI) or AWD(Jetta/GTI) are direct bolt ins..
AMU is the 225 (I think)
Old Apr 22, 2002 | 10:02 AM
raVen's Avatar
Member
They use APX for the 225 overseas.
Old Apr 22, 2002 | 10:06 AM
raVen's Avatar
Member
You want the APX engine. It has lower compression, and a K04 turbo, not K03.
Old Apr 22, 2002 | 10:07 AM
hoTTub's Avatar
Member
ah.....gotcha.....then yes, you want the APX =P
Old Apr 22, 2002 | 10:11 AM
raVen's Avatar
Member
AJQ for 180, and APP for.......I dunno yet! 8^)
Old Apr 22, 2002 | 10:12 AM
hoTTub's Avatar
Member
APP could be the 150hp TT
Old Apr 22, 2002 | 10:17 AM
raVen's Avatar
Member
Ahhh! You could be correct sir!
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 22, 2002 | 11:03 AM
NIIK TT's Avatar
New Member
Default Re: Ahhh! You could be correct sir!
My 180FWD has the APX code on it??????
I have found an AED unit to replace it.
Will this not fit then for sure???
thanks
Old Apr 22, 2002 | 11:15 AM
raVen's Avatar
Member
What country are you in?
