Can't stop modding!
Will do.
Build quality look excellent. The center resonator is much smaller than I thought it would be. The rear can is attached to the center pipe the same was the Forge is set up so I imagine the heat shield may need to be "modified".
More pics. Install will hopefully happen this week.
<ul><li><a href="http://www.boozebags.com/jwiegert/gallery/bbexhaust">http://www.boozebags.com/jwiegert/gallery/bbexhaust</a</li></ul>
Basically yes.
B&B builds the exhaust for APR. As far as I know there is no difference between this unit and the one sold by APR except the tips don't have the APR logo etched into them.
you can just bend the heat shield as needed. If you can still rotate the exhaust to make the tips
either go up or down but bolting the the muffler and center pipe together, and moving around at the cats. There's lots of play in the hangers to allow side to side; add washers under the hanger bolts to lower and bend hanger attachments to raise the exhuast.
