Cel hell.
Old Aug 21, 2007 | 06:11 AM
ZGTT's Avatar
Default Cel hell.
17963 and 16804 keep triggering the light.
Boost is set to spike to 23-24 and hold at 20-21
5.75 turns on the BM - yet I have "charge pressure max limit exceedded"
I have the 42 Draft Design downpipe with the high flow cat. I have no clue why it keeps faulting (Bank 1, Efficiency Below Threshold)
any thoughts out there?
(edited.. even though I am tossing a cel.. no limp mode. Car runs great still)
Old Aug 21, 2007 | 06:29 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Did you put the 90 degree block on your 02 to eliminate the CEL?
kodeTT's Avatar
Elder Member
Default maybe you have a leak somewhere...
or with the swapping of DVs...maybe you didn't clamp down a hose. happens to the best of us.
Old Aug 21, 2007 | 06:31 AM
ZGTT's Avatar
Default according to evan's site.. not needed.
"Will your downpipe cause a CEL?
Street series downpipes will NOT cause a CEL. Race series downpipes will cause a CEL. The CEL can be avoided by using an angle block adaptor on the second oxygen sensor. To learn more about CEL fixes please read our Test Pipe FAQs."
(I have a street series cat)
roadyTT's Avatar
You've got the post-cat O2 sensor blocker right?
Old Aug 21, 2007 | 06:44 AM
ZGTT's Avatar
Default no...
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1674851.phtml">I dont, and here is why.</a></li></ul>
Old Aug 21, 2007 | 06:54 AM
joe@vwvortex's Avatar
Default I've got an occasional 02 sensor code - but no CEL - I just clear it....
and don't worry about it. Sounds like it's something else as well.
Old Aug 21, 2007 | 06:58 AM
|everso!|'s Avatar
maybe your honking DV?
Old Aug 21, 2007 | 07:05 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Well?...>
All set-ups are just slightly different and react differently to mods. Put one on and turn the BM down a tad..Before you wring that little K04's neck...:-)
Old Aug 21, 2007 | 07:17 AM
ZGTT's Avatar
Default yea, I see that is my only option. boost has been turned down some already.
I am sure todays cell is the cat.
