center exhaust hanger
Here they are...
BRACKET: 8N0 253 461 C
RUBBER : (180) 1H0 253 147 B
(225) 1J0 253 147 C
BOLTS : N-900-744-01 (4 of them, not needed 'cause they should already be there)
Someone posted the part number 1J0 253 147 D for the 225 rubber, perhaps an improved item? Check with dealer first.
(225) 1J0 253 147 C
Well, my resonance disappeared from 3k rpm after the installation, but now appears at lower rpm.
Also, when driving under rain, the whole exhaust resonates badly and makes contact with the underbody.
A real can of worms.
Good luck!
Good luck!
If I remember right . . . the Fwd does not have this hanger . . .
When I did Kim's exhaust the bottom of her car was nothing even close to the TTQ. The place where the center hanger would go is about where the Fwd exhaust turns 90* to the drivers side. Plus the Fwd has the belly pan there as well.
If you are getting resonance I would check the area from the downpipe to the cat.
Options?
My exhaust (miltek) resonates around 3.5K RPM. The clearance from the heat shields and the body of the car is pretty good. I installed the center hanger and still no change. Are there any other options?
mbox
04-08-2005 07:19 AM
Mark P
36
04-27-2004 05:20 AM
