Central locking/ Manual Locking problems
My fob has worked fine up until shortly after I replaced a faulty car battery. I thought it might be the fob batteries, so I had those replaced. Still didn't work. Fob is transmitting a signal though. The central locking buttons inside the car have stopped working as well; however I can still open the trunk/ gas tank cover. I checked both central locking fuses, and both are fine.
I thought that perhaps my fob just needed reprogramming. However, the manual locks were not working when I purchased the car. This was not a problem as the key fob and central locking system never had any problems up until now.
I need help! I don't think it's the lock pump as the trunk still unlocks. What else can I check? Also, if somebody could walk me through figuring out the manual locking system that would be great.
The module is located in different locations depending whether you have a coupe or convertible. Best bet is to locate yours and get part number off of it. Then check eBay or something similar to find a replacement. They are hell expensive new so are a better deal to get used.
There are also a number of places to get them rebuilt like Module Masters and bba-reman. But of course your car is not going to run while the module is getting rebuilt.
Here is a pic from my coupe; the module is located behind the panel below the seat back latch on the left (driver) side.
Best of luck and Cheers!
Hope this helps.
