check engine light
They're going to trying to replace the 02 sensor again (might be faulty?). but other than that are there other common problems that I should look out for for 03' 1.8t cpe with 56k miles? this is my first audi and i really don't know how else to take care of it besides the on time oil change, tune up, and use synthetic oil. any suggestions or advice is greatly appreciated!
What was the code(s) that was stored?
Here's a list of codes.There are a lot of them so it's unwise to guess.
http://www.bentleypublishers.com/tec....dtc.table.htm
If your mechanic is competent he needs to have access to the Audi / VW factory code reader or a Vag.com.
Not just a generic scan tool.Something than can read specific audi codes (not just P -codes).
The tools can also monitor MAF and oxygen sensor operation.
If this is "hard" fault it should be easy to find.
If you prefer you can keep handling over the $$$ while your mechanic plays "guess the part". Then sell the car when you have had enough and then tell everyone what cr@p cars Audis are.;-]
