Is the climate control, in anyway, connected to the Bose stereo? (more)>>>>
I installed an aftermarket receiver, and now the climate control would not turn on. If I turn the lights on, the climate control's buttons light up, but the screen that shows the info wouldn't turn on, and the AC would not either. any suggestions why that might be? also, the center portion of the center console is blank. TIA
"also, the center portion of the center console is blank." What were your expectations here?
An after-market H/U is fully integrated into the TT's wiring?
As far as the climate control, how much did you dig into the DIN opening in where the head unit is?
Could you have possibly munged something up there?
Did you check for relevant fuses?
No Jeff, not that, I meant the portion that shows the temperature and stuff>>>>
I know that the top portion that shows the CD tracks still works because there's a washer fluid warning icon telling me to refill :-). and the bottom portion that shows MPG/Miles left in Gas is still working just fine. Maybe it's a fuse, you think so? Would you happen to know the fuse # in the fuse panel? Thanks a million.
pmark837
04-17-2005 12:32 AM
