Clutch Problem
Old May 23, 2000 | 07:36 PM
PalmSpringsTTr's Avatar
New Member
Default Clutch Problem
I have a TT roadster with about 1600 miles on it.
Last week we began having problems with the clutch. In first or second gear the clutch pedal does not come back up after it has been depressed. (You must physically pull it back up with your foot.) Additionally the clutch engages at different positions when the pedal is depressed.
OF COURSE the problem is intermittent and cannot be recreated by the mechanics at the dealership! We have replaced the master cylinder (clutch) but the problem still occasionally occurs.
Has anyone seen this problem before? If so please let me know. I'm afraid the mechanics are beginning to think I don't know what I'm talking about.
Old May 23, 2000 | 08:33 PM
Ego's Avatar
Ego
Junior Member
Default Re: Clutch Problem
I really assume that you've checked this already, but I ran into this with my 944 a while back. I felt like such a dolt after hemming and hawing about what was wrong with the car. Turned out that the top of the clutch pedal was catching on a loose wire and a little bit of loose carpeting. Stupid, simple problem. I doubt that's your problem, but if you haven't looked down there, take a gander. <p>
Chris Lawrence
chris@nrsys.org
1987 Porsche 911 Carrera
1985.5 Porsche 944
2001 TTQC 225 Brilliant Black/Aviator Grey, all options (ordered May 1st, 2000)
Old May 23, 2000 | 08:38 PM
New Member
Nope, that's not it. Looked at that first. Thanks tho
Old May 24, 2000 | 03:28 AM
MichaelTT's Avatar
Senior Member
Typically there is a 'return spring' located at the pedal end of the system...I can not see in this area since there is a under dash cover hidding mechanism. But in every car that I have owned there has always been a 'return spring'/tensioner. Might check for (1) such a item exists and (2)binding/part failure etc.<p>2001 Amulet Red 225TTQC
AMULETT
glaive
May 22, 2015 06:52 PM
lvv
Nov 24, 2003 02:43 AM
EDness
Nov 3, 2003 07:24 AM
Lucas_Gchips
Audi A3 / S3 / RS 3
Jan 2, 2002 04:54 AM
pdw
Aug 25, 1999 06:17 AM
