Cold start problem
My coolant sensor was replaced about a year ago, without any change in the problem. It is largely a small problem at this point, but my warranty expires in August, so I don't want to let a potentially big problem get away from me.
Any advice would be greatly appreciated.
Depending on your mileage, you may want to replace the fuel filter (if it has not been done in the last 40k) and run some techron through it....
Dealer will probably not consider it an issue...
Hans' advice usually works. The reason is that the tank saddles the quatrro driveline and there is only one "real" pump. When your fuel is low, the pump has to get the other side primed in order to build up pressure because it has leaked down overnight.
When the tank is full enough for the saddle to be wet, no priming is required.
