Coolant temp problems HELP
So, I changed my tbelt, serpentine belt, water pump, and tstat. Now for some reason, my temp gauge on the dash is steady middle when driving but when stopped it goes up to 1 bar past the middle.
On the climate control cluster it ranges between 96-102 C. I haven't seen it go higher than that. Also, I haven't really noticed the high fan coming on but I know the low does come on.
Any one know if this is normal? What can I do to fix this? Its wierd cause it only happened after replacing all those parts.
Re: Me too. shop claimed oem t-stats were made by Behr, but... I have same behavior as you describe
so far, highest i see on mine is 104. what about you guys. my low fan is on at the time thou
The Behr does not open up as far as the OEM
Someone posted an experiment on this board a few years ago. Placed a Behr and an OEM in a pan of water with a thermometer. Both began to open at identical temps but after a few minutes the OEM had opened much further than the Behr, thus explaining the slightly higher temps for the Behr. The OEM has better coolant flow.
ScarfaceNostra
08-31-2004 05:28 PM
