Coolant Temp Sensor Fail?
Old Oct 13, 2024 | 02:32 AM
HERROBERSTJG52's Avatar
Default Coolant Temp Sensor Fail?
Good Morning!
I have a 2003 TT 1.8 Quattro. My temp sensor on the dash will work sometimes and sometimes it will not. Very annoying to say the least. I did the "hidden code" trick and it read, after being driven for at least 2 hours, -10 Celsius. Which is way below freezing 😆. As I said it will go up to a normal temp (halfway up the dial) and then the rest of the time it will read as if it is stone cold. Fuel gauge works fine...Speedo works fine...RPM works fine as well...Pixels...well they are on the Fitz as well....I am pretty sure the temp sensor is failing. No puddle of fluid under the car or anything like that.So thoughts on this one? Never have owned an Audi as I have owned a Boxster for the last 10 years before this car...Thanks in advance!
Paul
Old Oct 13, 2024 | 05:02 AM
Vegas-roadster's Avatar
25 Year Member
Replace the sensor. Failed sensor does not cause leaks on a TT.
Butch Lloyd
Jun 13, 2023 07:58 AM
fjasper
Audi allroad
Dec 18, 2009 04:06 PM
Jason Trumpio
12
May 26, 2007 06:11 PM
vincenzo
Feb 12, 2003 09:36 AM
plexxx
Feb 4, 2002 04:21 PM
