couple fault codes >>
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
16716 - Knock Sensor 2 (G66): Signal too Low
P0332 - 35-10 - - - Intermittent
any ideas? I've gotten them in the past and cleared them... but they like to come back
be careful of the plastic clip that holds the sensor...
it was easy to remove it, but difficult to put it in due to location. I had a difficult time to slide it back in...and snapped it in half, since it wasn't lined up correctly. had to buy a new one...actually 3, just in case, but found out that the old 'O' ring was actually still seated (which didn't allow the new green sensor to seat properly). make sure that everything is free and clear...and open up the cap for the resevoir and close it to create a vacuum so you won't spill too much pink fluid.
Jitter
VAG-COM Discussion
12-11-2011 12:10 PM
~DonQPremiumTequila~
06-11-2008 09:22 AM
Holographic77
04-03-2006 08:12 AM
TTBella
15
10-31-2005 03:44 PM
3Scanner
17
09-12-2005 07:58 PM
