Couple questions...Glovebox & A/C question
Glovebox:
*handle broke off
*I see the lever that you would push to the right to "open" the glove box
*I push the lever to the left but it will not come down...seems caught...Tried a little more than force w/o breaking the box
*If i push up the lever clicks back to the left
Any ideas?
A/C:
*Car seems to drive fine
*I had the dealer swap A/C panel due to irritating A/C panel fan noise.
*TWICE it has happened since I have replace panel (2 times in the last 2 months)...the A/c would blow hot air as if the compressor isn't running...also the digital thermometer is registering -20 degress or something ridicules like that...then if i drive long enuff...it counts backward towards the correct temperature.
Other than that the A/C works fine...
weird...I know I have the extended warranty but I would be a waste of 50 buck if I can not replicate the problem while it is at the dealer.
Any input would be welcome...
Thanks...
*handle broke off
Any ideas?
A/C:
Thanks...
quattro.pilot
Audi Original "S" Cars
09-26-2008 10:01 PM
S5LA
01-03-2008 01:01 PM
