Crankshaft Position Sensor Replacement
in this episode we will be replacing the crankshaft position sensor as I've had a long starting problem now and again and it being over 20 years old, I've already replaced the fuel pump and the camshaft position sensor and have no fault codes the part I fittedfebi bilstein 36175 Symptoms of a Bad or Failing Crankshaft Position Sensor Issues Starting the Vehicle. Intermittent Stalling. Check Engine Light Comes On. Uneven Acceleration. Engine Misfires or Vibrates. Rough Idle and/or Vibrating Engine. Reduced Gas Mileage.
nathanwind
16
04-11-2019 03:31 PM
