Cylinder pressure blowing past spark plug seal? Actually lifting coil pack>>
Ummmm, that would be bad.
Check if the plugs are tight? One cylinder or all? Something here definitely doesn't sound right.
Take them out, make sure there's a washer, and only one washer on the plug and none in the seat area. Check the seat area for debris or gouges. Install new plugs or swap plugs from cylinder to cylinder if it's only one or a few of them doing it, see if trouble goes with the plug or stays with the hole.
You have a problem...That should not happen...
The plug(s) doing that must not be properly installed or the seal is faulty because cylinder pressure should not blow by a properly installed spark plug with a correct seal.
I would recommend replacing the plugs with the correct kind specified for your TT. If you still have a problem, then the spark plug hole
in the cylinder head may be damaged.
are you sure that's what's going on?
is the car actually running like that? it can't be running well if at all. isn't the coilpack bolted down? are you sure the coilpack isn't just loose and popping up off the spark plug?
Joao
03-05-2008 04:00 PM
HACK THS
01-11-2005 03:03 PM
TwnTrbo
18
07-20-2003 09:01 PM
Avantgarde
09-30-2002 06:17 AM
