Do I need regular re-allignment or camber kit?
I have a 2001 Audi TT Roadster 225HP Quattro with an Eibach pro kit 1.1'' drop all around. I recently noticed some uneven wear to the inside of my rear tires. Can this be fix with a regular allignment or do I need to buy a camber kit. If I do need a camber kit will a 1/2 K-Mac do the job or do I need the full kit? I'm also thinking about throwing on 25mm spacers to the rear, will this also throw off my camber even more?
You need some camber correction..>>
I had the same set-up...<ul><li><a href="https://forums.audiworld.com/tt/msgs/1101053.phtml">Read why here......................</a></li></ul>
Thanks for the extremely usefull info Steve but...
which kit do you recommend for my setup? The K-Mac 1/2 rear kit or the full rear kit with my 25mm rear spacers to account for?
Tu
Tu
I think...>>
1/2 will be fine but if you want to easily adjust toe and have a little more headroom with adjustments, go with the full kit...I had exactly the same and used the full kit so I could make adjustments easier.
Here's some Kmac adjustment tips:<ul><li><a href="https://forums.audiworld.com/tt/msgs/1577229.phtml">https://forums.audiworld.com/tt/msgs/1577229.phtml</a</li></ul>
One more question hahahah......
Do you recommend installing the spacers prior to the K-Macs or does it not make a differance? I have a feeling that it does.
Tu
Tu
Okay more suspension questions-If I get Eibach and bilsteins do I need frt or rear camb kit or both?
TittieTwister
13
03-16-2004 03:52 PM
HHTT
10-28-2003 06:14 PM
