does any one know were the ecm or relay -J271 is located? thanks
Old 09-23-2004, 03:26 PM
audittblu2's Avatar
Old 09-23-2004, 03:32 PM
Member
MOBlueTT's Avatar
What problem are you trying to solve ?
Old 09-23-2004, 03:35 PM
audittblu2's Avatar
Default Re: What problem are you trying to solve ?
car wont start i changed the camshaft position sensor and the other code is 17925 steve schwing says the bently manual states to check relay j271 -ecm. In a nut shell car won't start
Old 09-23-2004, 03:38 PM
AudiWorld Uber User
TTschwing's Avatar
Default I can have a pic in a little while...>
eating dinner! It's under the dash. Also check the fusable link (2nd from left) at the battery as Jeff mentioned..
Old 09-23-2004, 04:07 PM
AudiWorld Uber User
TTschwing's Avatar
Default Here it is.....
Check Motronic Engine Control Module (ECM) power supply relay -J271
The motronic Engine Control Module (ECM) power supply relay -J271- supplies voltage to the ignition coils with power output stages and the Engine Control Module (ECM) at pin 121. Disconnect voltage supply relay -2- below left cover at bulkhead.
Check fuse S10 (in fuse holder, position 10).
Note:
To remove the protective hood for the TT Roadster relay carrier, disengage at the bulkhead and swing downward. Disconnect additional harness connectors at Mass Air Flow (MAF) sensor, if necessary
Check Voltage between coil pak plug pins 1 and 4. should be approx. battery voltage (ignition on)
<img src="http://images7.fotki.com/v110/photos/7/7305/776256/coilpakplug-vi.gif">
Relay location (#2) is referred to as at the bulkhead...Might be in the engine compartment..Haven't looked:
<img src="http://images8.fotki.com/v111/photos/7/7305/776256/relay-vi.gif">
Old 09-23-2004, 04:54 PM
JustJeff's Avatar
alldatadiy.com?
Absi Amri
Q7 MK 1 Discussion
18
02-05-2024 07:21 AM
VorsprungTT
11-26-2006 07:17 AM
Jon-1.8t
09-29-2004 10:17 AM
audittblu2
09-24-2004 04:32 AM
CastleCQ
05-30-2004 03:45 PM
Quick Reply: does any one know were the ecm or relay -J271 is located? thanks
