Does anyone esle have trouble picking up stations
with their Bose "Premium" system? I can't get certain stations very well that my other car radios easily picked up.
I thought maybe something's wrong with the radio/antenna.
Thanks.
Thanks.
Re: Does anyone esle have trouble picking up stations
What sorts of stations? AM or FM? I know that there was some discussion recently about a small "mod" to provide an auxiliary grounding source for the Haldex, to reportedly improve AM radio reception.
I haven't seen much discussion about FM reception, though.
More than likely a grounding issue. Cycle the rear defroster a couple of times....
if you hear a loud pop and/or reception improves/worsens, it is definitly a grounding issue. Since I rarely listen to AM (only for Raider games) I'm waiting till my 30K service to take it in - last time it was there, they said the radio was fine and the reception issue was due to my window tint - total BS as the defroster trick can get the AM reception to work almost every time.
Good Luck,
Good Luck,
elmer...the coupe has an antenna integrated into the rear windshield, which guarantees...
poor reception (relative to a stalk antenna)...in addition, the antenna wire runs next to the (ungrounded) haldex unit -- and it can pick up a static charge which really messes up AM reception...that can be fixed by grounding the haldex unit (larryTT had some pictures of that about a month ago here)...unless you change the antenna to a stalk, however, there's not much you can do for overall reception improvement (unless you get satellite radio -- such as xm -- which is fabulous!)
Thanks for the response. I have a roadster with the stalk
antenna.
The radio in my wife's '02 Passat is much better at pulling in stations, plus the sound is spectacular(It's the Monsoon).
Thanks for the tip Ted- I'll try it. The dealer told you your
radio reception problem was due to window tint??!
Where do they get the gaul to insult your intelligence like that???? AAUUGGGHHHH!!!!!!!
craigd0013
13
02-07-2006 06:17 AM
Jeremy Clarkson
14
03-29-2002 08:57 PM
Audi_2000_1.8t
08-30-2001 08:21 AM
