ESC module
Old Aug 29, 2008 | 03:10 PM
sputnik2168's Avatar
New Member
Default ESC module
I just found out my ESC module is going bad and it cost $1300. I know you need it to help stability of the car when your driving but has anyone had the same problem? Also has anyone removed it and drives without it?
Old Aug 29, 2008 | 03:16 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default You mean ESP? If so, it is integrated with ABS - you can't remove one without
the other. Traction control is in the list as well. You can drive without it - cars didn't have them for almost a century. That said, you can likely get one from a wrecked TT, or have yours rebuilt for much less than a new one.
BBA does ABS units...<ul><li><a href="http://www.bba-reman.com/catalogue/DetailedProduct.aspx?DetailedProduct=572">http://www.bba-reman.com/catalogue/DetailedProduct.aspx?DetailedProduct=572</a</li></ul>
Old Aug 30, 2008 | 07:16 AM
New Member
Default Re: You mean ESP? If so, it is integrated with ABS - you can't remove one without
Man, I really appreciate the link. I haven't looked at the manual to change out this part, do you think its difficult to remove and replace
Old Aug 30, 2008 | 08:48 AM
Tech Guru
Default The hydraulic unit is pretty easy to get to and replace. You will need a VAGCOM
when you put the next one in, as you will have air in the hydraulic unit that you will need to purge. You can cycle the pump with VAGCOM.
97urS6
Feb 16, 2019 02:51 PM
dieselfitter! 251
Sep 17, 2008 11:04 AM
A4orce84
Jun 21, 2008 05:52 AM
SForked
Dec 12, 2005 10:26 AM
Mr. Head
Apr 20, 2005 02:34 PM
