Fix for window not going down!
Old Jan 31, 2006 | 09:04 AM
TTest-D3MON's Avatar
Default Fix for window not going down!
The other day my passenger window stopped working, and would just make a ticking sound and not move the window at all. So here is a detailed tutorial on how to fix it:
1. remove door panel
2. locate motor and look for any obvious signs of damage and fix.
3. If no damage found, consult forums to find that everyone says the motor is gone and they just got a new one.
4. Move on to plan B, and take favorite "plan B" hammer (or stick if you prefer) and beat motor until it decides to work.
5. replace door panel.
6. Rename "plan B" hammer to "plan A" hammer
Hope that helps someone and saves money :-)
Old Jan 31, 2006 | 09:14 AM
TTGram's Avatar
Member
Default Last year my window stopped working so I bought a window motor from ......
a salvage yard. Before I could install it the window started working and has been fine since.
Old Jan 31, 2006 | 09:27 AM
TTagz's Avatar
Senior Member
ah yes, the "Technical Tap", that is always my plan A
Old Jan 31, 2006 | 09:29 AM
Bracketracer's Avatar
Default sorta like fixing a starter...
and it will work for a while, but will eventually fail for good. There are even times that you can perform the plan b fix without removing the door panel. But use your fist instead.
MKLW
Oct 31, 2011 01:39 PM
Bob Loblaw
Jan 17, 2007 11:26 PM
DRAGON88
Oct 31, 2005 02:36 PM
Absolute Santorin
Aug 1, 2004 05:51 PM
ondo
Jun 24, 2002 10:08 AM
