Forge Adjustable tierod questions... Anyone using these?
Is anyone using these tierods? Is the Kmac kit a better alternative? I want to lower the car and really want to get the alignment dialed in well.
Bobby
Bobby
I don't think either the Forge or Kmac's are a "better" solution, however
since you only need half the KMac's - they are a less expensive alternative. I've seen the Forge arms in person and they are a much better design than say the Griffen modified arms. I went with Kmacs solely due to cost considerations and the fact that I had a TT with the control arm recall and have 4 brand new control arms on my car.
Forge Tie bars
FYI thought this might help. The Forge arms are brand new original tie bars. They are reinforced around the fork end area, and the adjusters are manufactured from high tensile steel, that is zinc plated to stop rusting. The OEM bushes are removed and replaced with Powerflex Polyurethane bushes. As usual this product carries the Forge lifetime guarantee.<ul><li><a href="http://www.forgemotorsport.com/tt.asp?cat=auditt&product=FMAUTB">Forge adjustable rear arm details</a></li></ul>
TittieTwister
11
03-23-2004 03:55 PM
black225TT
03-22-2003 05:04 PM
golem9000
05-22-2002 09:42 PM
