Found the problem.
Old Jan 21, 2008 | 03:00 PM
HugeTTs's Avatar
Default Found the problem.
My old thread sunk, so I'm making a new one.
We pressure tested my car again, I must have done it wrong somehow because there is a huge hole in a hose under my intake manifold.
Its coming off of some Y thing. I guess part of it pressureizes the crankcase.
Is this common? For those of you that don't know, my car, when floored would hit 20psi, sink a tad to about 17psi then the *** would fall out to exactly 10psi...
Do you think the leak under the intake manifold would do that?
I'm just stoked I found AN issue, even if it isn't THE issue.
Old Jan 21, 2008 | 03:08 PM
JohnLZ7W's Avatar
Default pressure tester might not find leaks in hoses attached to the intake manifold
since the throttle is going to be closed.
TTinCT's Avatar
Rest In Peace
Default Probably the major one....but may not be the only one..>>>
more than likely....start with that...as the rubber succumbs to heat, more will need replacing......dare i say there will be one or two others....IMO
Old Jan 21, 2008 | 03:35 PM
coasTTal's Avatar
Default Since there are several small vacuum hoses connected to the manifold, I think you would find leaks.
I just did the pressure test thing this past weekend and was finding leaks in the small hoses above the engine. Some of those go back to the manifold.
Old Jan 21, 2008 | 04:01 PM
JohnLZ7W's Avatar
depends on where the other end of them is attached I guess
sullyj
9
Aug 21, 2017 07:31 AM
PKBlu::E30 Hunt
Dec 12, 2004 07:41 PM
fairenough
20
Oct 7, 2003 08:45 AM
