Getting Concert II Radio out of SAFE mode...
.....Curious as holding the FW and RDS for 5sec. does not toggle the display from SAFE to 0000....what's up with that? I have the newer bose concert II...
(Joe-FAQ) Provided these instructions from the manual for someone
a couple of weeks ago.
To cancel the electronic lock-up, you must enter the correct code number.
It is essential that the following steps be carried out in the correct order:
Turn on radio - the word "SAFE" appears in the display.
Press the "SCAN" and "RDS" buttons SIMULTANEOUSLY and hold them down until "1000" lights up in the display.
Release buttons. DO NOT, UNDER ANY CIRUMSTANCES, CONTINUE HOLDING THEM DOWN OR PRESS THEM ONCE AGAIN, this would cause the radio to consider the number "1000" to be the input code number.
Use station buttons (the first four from left to right..they are referring to the diagram here and you don't have the manual, so I'm trying to translate it for you)
Enter first digit with the station button to the far left and then the next to the right to enter the second digit and so on. The last two buttons on the right should not be used.
Once the code is shown in the display, press the "SCAN" and "RDS" buttons again SIMULTANEOUSLY and hold them down until the word "SAFE" appears in the display.
Release buttons. Soon afterwards, a frequency will be displayed. The radio can now be used again.
BBsTT
10
08-17-2008 02:49 PM
sTTay down
05-02-2005 06:00 AM
