Horn Replacement ( SORRY )
Hey all, I want to replace the factory horn with hella loud horns, I cant seem to find the existing factory horn under the hood.. Anyone know where it is located? Do you think it is a easy job. Thanx
IS REMOVING THE NOSE EASY?
Ive seen the diagram to remove the nose but it looks so too hard? Is removing the front easy? Is there any steps to do it? Thanx ( Sorry for stupid questions, I just need help )
Yes.. (m)
It is quite easy, if you have the tools. You need a lot of torz bits, deep metric sockets, and a way to take the wheels off.
how to remove the nose:
First you have to jack up the car to get the wheels off. Then you have to peel the mud flap/wheel well lining by removing some torx bolts. Then you have to take the 2 10mm nuts off. They are at the corner, and require a very deep socket to get them out, but it is not too hard. LOOSEN, and I mean only loosen the torx bolts that hold the black side clip. Then you have to take off the plactic civer above the nose by popping the plastic fasteners out and removing the 6 silver torx bolts holding the nose on. Then there are 2 phillips screws under the nose that you should take out. Then take the nose off and unplug the aliens, be sure to cork the washer fluid pipe, you can also just reemove the whole alien fixture by unclipping them as an alternative. It is pretty easy.
VonPooper
09-05-2008 06:22 PM
computrtutr
05-31-2008 02:35 PM
andysprague
03-09-2006 01:39 PM
zxj24
21
01-08-2005 07:01 PM
1.8Steve
07-09-2001 04:26 PM
