I need opinions (re: brakes)...slightly long.
I mentioned a few days ago that I'm getting a grinding noise when braking. I was already thinking of getting new pads to cut down on the brake dust, so now I'm thinking new rotors as well. Should I:
A. get some slightly used rotors (rear only) from a fellow AW'er and do the install myself (using Jeff Bipes' How To). Cost is around $70 for rotors shipped plus my install time.
B. Go to stealership and get OEM rotors installed (rear only). Cost is $525.
C. Get some aftermarket rotors (f & r) and pads and install them myself. The ones below on ebay are a possibility. Cost will end up around $400 plus my time.
Do you guys think the ebay rotors are any good? Do I need/want vented rear rotors (2000 180QC)? The set on ebay is drilled/vented fronts and drilled/solid rears.
Thanks for your opinions. Any info you can give me is greatly appreciated.<ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=33564 &item=2477088710&sspagename=STRK%3AMEBWA%3 AIT">ebay brembos/zimmermans</a></li></ul>
I would get Zimmerman front and rear with new pads all round
if that is within the budget. If not, I would get some OEM rotors on the cheap. I can help with the install btw. I have't done any brake work before but I would be happy to help out.
JD797
15
05-14-2007 11:00 AM
loopy59
05-14-2005 09:45 AM
Orcae Ita
02-17-2005 01:37 PM
UnionGuy
06-02-2003 03:58 AM
