i turned on my car and boom! a engine oil pressure icon comes on with "sensor" written under it...
Old 11-12-2002, 08:09 AM
New Member
OOOO_TT's Avatar
Default i turned on my car and boom! a engine oil pressure icon comes on with "sensor" written under it...
and then it just went away...i checked the oil and it is just right...anyone know what this could be?
thanks
Old 11-12-2002, 08:11 AM
New Member
OOOO_TT's Avatar
hmmmmmmmmm...
Old 11-12-2002, 08:13 AM
JustJeff's Avatar
Default Indication that your instrument cluster is about to take a dump....
this is the exact problem mine had, when my first cluster went bad.
Don't worry, the symptom will return.
Old 11-12-2002, 08:20 AM
GoKart3's Avatar
Default Yup.. electrical anomalies are the first sign that it's time for a new cluster. I'm just >>
about to have my 3rd one installed.
Old 11-12-2002, 08:23 AM
RoninTT's Avatar
Default Oh nooo!! On cold mornings <35%, mine has been giving me the low coolant warning, then goes away.
Coolant level is fine though...know where I can get a cheap cluster? :-/
Old 11-12-2002, 08:24 AM
New Member
OOOO_TT's Avatar
Default so what should i expect in the coming weeks? more
my cluster has been going bad, ie. fuel guage not reading correctly, sticking speedo RPM,temp,etc...
so what should i expect? will i be able to drive my car?
thanks
Old 11-12-2002, 08:32 AM
SparTTan's Avatar
Damn, my tach has been sticking lately. Out of warranty soon; I'd better have that replaced (again!)
Old 11-12-2002, 09:49 AM
JohnLZ7W's Avatar
When are you going in for yours? I still need to have mine fixed as well. Safety in numbers?
Old 11-12-2002, 10:00 AM
JustJeff's Avatar
Default sure, you can drive it, but i'd sure make a call to my favorite Service Tech. and tell them...
to order you a cluster, 'cause you are comin' in with a bad one.
Old 11-12-2002, 12:04 PM
Junior Member
Detailers Paradise's Avatar
Default Mine was doing the same thing...
Turns out is was the sensor in the coolant reservoir. It was a PIA to troubleshoot since it didn't seem to happen every day. Well actually it did...except when it was at the dealer.
petek's imolavant
09-02-2012 12:15 PM
ModifiedA4
04-25-2007 05:10 AM
doubleTTrouble
11
11-16-2005 10:22 AM
doubleTTrouble
11-10-2005 04:27 PM
ericwarren
02-15-2004 03:04 AM
Quick Reply: i turned on my car and boom! a engine oil pressure icon comes on with "sensor" written under it...
