Instructions for hardwiring V1 in 225R
You have two options (I think)
<center><img src="http://www.ebradstreet.net/TT_V1_Installation_o2bnme.jpg"></center><p>You can take out the under-dash and tap into the accessories wiring (yellow wire I believe). Or you can go into the fuse box and pick an un used slot.
In either case, the wires can be hidden in the cracks of the dash and windshield plastic. You shouldn't have to take 'everything' apart to accomplish it.
Agreed. Detailed hardwiring instructions would be very nice.
I'm just running the V1 from the cig lighter right now - I'll pull the remote display and hardwiring kit from the BMW probably tomorrow, and give the hardwiring into the TT a shot this weekend. Detailed instructions (or at least a 100% certainty on which wire to use and where it is located) would be MUCH appreciated.
You can search AudiWorld using Google . . . instructions inside
Go to <a href="http://www.google.com">Google</a> Then type in what you are looking for followed by <b>site:AudiWorld.com</b>
Like this: <b>valentine 1 site:audiworld.com</b>
It works better and faster than the old AudiWorld Search.
Re: easy solution
James...Installed mine on the left side of the dash next to the A pillar . 1 strip of velcro did the trick and no windshield obstructions. The wiring ends up being only 1 foot long. Tap a switched fuse for power.....Picture when I get home!
yourk
08-07-2003 04:25 AM
