It's SO nice having a sway bar bushing that no longer makes noise! <big smile :))))) >
#11
HA! same here...I just got back home from using the lift - 2.5hour + $34
= oil change, replace rear springs, replace/lube sway bushings
not a bad deal.
now, to wash the salt off the car, an change the pollen filter. where is that filter located?
not a bad deal.
#16
I gotta do my filter soon too...
You can get at it from under the hood...passenger side...kinda stuffed under the plastic molding. I believe the manual has the exact location of it...
#20
Re: Do Powerflex bushings fit stock bar with the plastic fitting removed? What size?
there are 3 sizes for that bar depending on your year and if it's a quattro. i had mine greased and the sound went away...for only a week.
appearantly those bushings are in a tight spot and very difficult to change.
esanmiguel
02-13-2006 01:07 PM
After two weeks, the rear H-sport sway bar still has a clunking noise... Anyone have the same issue?
Potomac2.7Tee
9
01-02-2004 02:11 PM
cpayne
Audi Original "S" Cars
02-27-2003 07:30 AM
